Got fire got fuel pressure, but car won't start. Not sufficient voltage at injectors.
Jan 28, 2020 at 2:30 AM
CARADIODOC
✓Experienced Mechanic
The injectors and ignition coils are tied together, and are fed from the same source, the automatic shutdown, (ASD) relay. What tests have you performed and what were the results? Have you read the diagnostic fault codes? What led up to this problem?
