Engine does not crank?
105,000 MILES • 1.4L • 4 CYL • TURBO • 4WD • AUTOMATIC
HARD-TIMES
Car won’t crank starter was replaced, fuses and relays are good, battery good. Wires to the starter seem good.
Sep 4, 2023 at 2:51 AM
  • 110,248 POSTS
Have you tried starting it in neutral? If so and that made no difference, we need to start checking fuses and the starter relay.
There are multiple fuses for the circuit to work. I attached the wiring schematic below for the starter circuit and highlighted all the fuses and the relay. Note the fuses are in different fuse boxes.
When you check the fuses, confirm there is power to and from them.
Here is a link that you may find helpful:
If all fuses are good and have power, remove the starter relay and switch it with a different one in the box having the same part number. If there isn't one, here is a link that explains how to test a relay and its circuit:
Let me know what you find or if you have questions.
Note: I had to cut the schematic in half to make it readable. I did overlap the two so you can follow from one to the next.
Sep 4, 2023 at 2:42 PM
