Turns over, but won't start. What things to check for?
180,000 MILES • 3.0L • 4 CYL • 2WD • AUTOMATIC
TUTPOT65$
Turns over, but won't start. what things to check for?
Dec 31, 2018 at 1:26 AM
Here are a couple guides that will help with getting us started. We need to check for fuel, spark, and compression and this will cover common things to check.
https://youtu.be/dCjmRL3p4Cs
The most common cause of this is fuel related so we need to start with checking the fuel pressure.
Here is a guide that will help with this.
Once we know what the pressure is we can take the next steps which would be checking for spark. So, we need to remove a plug and hold it against the block while the engine is cranking. Also, take a look at the plugs and make sure they are not damaged or fouled.
Below is a chart that will help with this.
Please run through all this and let us know what you find with this.
Oct 23, 2021 at 4:51 AM
