No start
258,150 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
MACKREL30
Yesterday I remove the starter took to Advance auto parts bench test it and it fail. So I replace it, but when I went to turn the ignition it wont crank so what I did was jump start the starter with a jumper cable and it start up, but when I put car in gear it just shut off.
Jul 14, 2016 at 4:20 AM
HMAC300
  • 48,601 POSTS
check battery for condition including load test. then try resetting your security system it may have set it off when you took starter out. if no manual look online for your car.
Jul 14, 2016 at 4:56 AM
MACKREL30
Okay, also when I bought this vehicle from private owner years back, the car came with kill switch I do not know if have something to do with alarm system because also have its own red light that blinks. Once car is start the kill switch light goes off.
Jul 14, 2016 at 5:06 AM
HMAC300
  • 48,601 POSTS
well there is abuilt in security system on all cars after 1997 so you can have the kill switch off that is just something else to screw up on you.
Jul 14, 2016 at 9:58 AM
