no start
95,000 MILES • V6 • 2WD • AUTOMATIC
KRGTRINI
no start, battery, fuses, relays, start and alternator all seem to be fine even the connectors are clean.
will a computer scan diagnose the no start issue?
Sep 5, 2017 at 2:02 PM
  • 31,937 POSTS
If the problem is related to engine management, it should log a code, so that will be the best place to start. do you have spark, injection pulse, fuel pressure? can you hear injectors clicking if you hold a screw driver against it and place your ear on the other end. also, pull a plug to see if it is flooded.
Sep 5, 2017 at 9:13 PM
KRGTRINI
did a scan and came up with code u1000 communications troubles.
Sep 6, 2017 at 6:51 AM
  • 55,743 POSTS
This sound like it can be one of two troubles first lets check the fuses and relays that run the system.
Here are two guides and some diagrams (below) to help us get started:
Start with fuse # 1 and 14 and the ECM relay
and
Please let us know what happens so it will help others.
Cheers, Ken
Sep 7, 2017 at 3:46 AM
