My vehicle will not start. I have replaced the crank sensor, spark plugs and ignition coils. When that did not help I started testing the wiring to cam sensor, crank sensor, and the ignition coils. The vehicle has fuel pressure. But it does not have a signal from crank sensor, cam signal, and none of the coils has a reference pulse when cranking over the engine. I am thinking its the ECM but not sure about the variable timing sensor. Am I forgetting or do you know of any other test I have not done?
Thanks,
Shawn Savage
Thanks,
Shawn Savage
Jan 25, 2018 at 12:19 PM
