No speedometer, no ABS, no traction control?
85,000 MILES • 4 CYL
CA7922303
  • 165 POSTS
Speedometer intermittent, no ABS, traction control, low power brakes, brake light on dash. Vehicle no change from usual operationally.
Nov 1, 2024 at 5:13 AM
  • 55,628 POSTS
Did all these problems happen at once? I would check the brake fluid and the brake pads, but I have seen the ABS control module go out and cause this issue. For the ABS and traction control the speedometer issue will cause these warning lights to come on because they are all produced by the ABS control module. We should do a CAN scan to confirm the issue. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change the module out in case a code comes up for it. Check out the images (below). Please let us know what happens.
Nov 1, 2024 at 5:46 AM
CA7922303
  • 165 POSTS
Yes, all at once and I don't notice any difference in anything operational.
Nov 1, 2024 at 6:55 AM
  • 55,628 POSTS
Yep, I would run the codes and replace ABS control module when a code is stored for it.
Nov 2, 2024 at 2:23 AM
CA7922303
  • 165 POSTS
AutoZone code reader showed replace abs module. Started behicle, turned steering wheel all the way in both directions twice and drove vehicle for about 15 minutes. Turned engine off, started back up and no warning lights, no check engine light. Steering sensor reset?
Nov 9, 2024 at 7:58 AM
  • 55,628 POSTS
What was the code number and did they clear the codes as well?
Nov 10, 2024 at 12:58 AM
CA7922303
  • 165 POSTS
P0500 and C1439.
Nov 10, 2024 at 11:06 PM
CA7922303
  • 165 POSTS
AutoZone did not clear codes. Check engine light came off along with all other warning lights when I reset the steering position sensor I believe.
Nov 10, 2024 at 11:09 PM
  • 55,628 POSTS
It could be the spiral wire behind the steering wheel but these codes are leaning toward the ABS control module.
Code: P0500 - Vehicle Speed Sensor Malfunction
Code: C1439 - Wheel Speed Sensor Signal Malfunction
I would clear the codes once the ABS module once the job is completed.
Nov 12, 2024 at 2:47 AM
CA7922303
  • 165 POSTS
Bought a CAN scan tool and have photos of results. Erased all codes and now everything works properly even the radiator fan comes on without jumping the relay, which I thought was corrected when I replaced the temperature coolant sensor, but was not. Haven't driven it much to see if issues come back yet.
Jun 1, 2025 at 3:04 AM
CA7922303
  • 165 POSTS
Also, P0500 was showing and there is live data that you may want the info on. Let me know what info to send? Thanks for your help.
Jun 1, 2025 at 3:06 AM
  • 55,628 POSTS
It sounds like the spiral wire can be bad, but you should try a zero point calibration for the steering angle sensor which you should be bale to do with the CAN scanner. Just navigate to the ABS system and find the prompt for it. It should tell you to turn the car on without starting the engine with the steering wheel straight. Then follow the instructions on the scanner. If the code does not clear I would replace the spiral wire.
Jun 2, 2025 at 3:12 AM
