Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Grand Prix
Drivetrain
Transmission
Symptoms
Not Shifting
No speedometer and transmission does not shift out of first gear
2002 PONTIAC GRAND PRIX
23,788 MILES • 3.8L • V6 • 2WD • AUTOMATIC
BERNADETTE MCFALL
MEMBER
1 POST
We had the speed sensor change and it drove good for a day or two but the speedometer stop working and now it does not shift out of first.
Aug 4, 2018 at 6:32 AM
Experienced Mechanic
Good afternoon.
The reason the transmission will not shift is the speedometer is not sending a signal to the PCM.
The first thing I would check is the connector at the sensor. They are common for failing from either loose pins, damaged pins or burned pins.
Images (Click to enlarge)
Aug 4, 2018 at 6:58 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
