no spark to the injectors
2000 INFINITI QX4
150,000 MILES • 3.3L • 6 CYL • 4WD • AUTOMATIC
AMY PROMAN
injectors has no spark and the fuel pump runs all the time.
Jun 19, 2017 at 5:58 PM
  • 55,224 POSTS
It sounds like you have two problems, first the fuel pump relay is stuck on and needs to be replaced and for the spark it sounds like you need a crankshaft angle sensor.
Here is a guide that will show you what you are in for when doing the job.
Here are diagrams (below) on where it is in your car.
Cheers, Ken
Jun 22, 2017 at 4:09 AM
