Shut off while driving, engine cranks but does not start?
159,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
PAUL ROGERS2
truck stopped ruining while driving, cranks will not start. replaced all ignition components CKP, cam sensor, cap, rotor, coil, and ICM. the coil not getting signal.
Feb 14, 2025 at 3:40 AM
  • 55,688 POSTS
I would remove the distributor cap and crank the engine over to see if the rotor is turning. Also, does the pink wire at the coil have power with the key on? Please go over this video which can help:
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Please go over this guide and get back to us.
Feb 15, 2025 at 2:41 AM
