No spark ignition fuse keeps blowing
126,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
DARREN HARRIS2
Was driving to work van stopped running, try to start but no start, no spark, no fuel pump. Ignition fuse keeps blow every time I try to turn it over. can’t check relays under the hood because when try to turn on key fuse blows.
Mar 2, 2019 at 10:47 PM
Good morning,
What fuse number is failing? so I can look for a diagram of what the fuse controls so you can search your failure.
Mar 3, 2019 at 1:13 AM
DARREN HARRIS2
On the inside fuse panel it is fuse 16 that says ignition feed 15A. please I need help.
Mar 3, 2019 at 4:14 AM
Okay, I attached a diagram of all that fuse 16 controls. You need to unhook all the components that are controlled and then see if the fuse still blows. If It does, it is a wiring harness issue. If it does not then you need to plug one component back in, one at a time until the fuse fails. Then you know the failure.
Mar 3, 2019 at 4:29 AM
DARREN HARRIS2
Oh, my this may that a while. but I may have to take it to a garage or have someone look at it that’s just more then I know how to do.
Mar 3, 2019 at 4:43 AM
Okay, that is a good idea.
Keep me updated.
Mar 3, 2019 at 4:49 AM
