No spark from distributor
118,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
TOMMYGUNN15
My car ran perfectly into the garage and it never started again. I pulled the spark plugs and found no spark. Went to YouTube and looked at it and most common was needing a new distributor so I bought one and put it in and I've got the same problem. I've been threw all the fuses I could find and all were good. I'm lost and wife is having a fit to get her car back. any help would be appreciated. I do have pretty good electrical skills. Hard to get exact information about this. Thanks
Jun 19, 2019 at 8:49 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Since you have no spark, my first suspect is a bad crankshaft position sensor. Take a look through these links:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
_________________________
Now, before I suggest replacing the sensor, we really need to be sure it is bad because it is behind the timing belt cover on this vehicle. What I normally would do is check for an RPM signal when cranking the engine using a live data scanner. If there is no signal from the crankshaft position sensor or no RPM signal, the sensor is my first suspect.
If you find it to be bad, here are the directions specific to your vehicle for replacement. The attached pics correlate with the directions.
1997 Acura Integra Sedan L4-1834cc 1.8L DOHC MFI
Procedures
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Crankshaft Position Sensor Service and Repair Procedures
PROCEDURES
1. Remove the wheel well splash shield.
pic 1
2.Loosen the adjusting bolt and mounting bolts, then remove the P/S pump belt.
pic 2
3.Loosen the adjusting bolt and idler pulley bracket bolt, then remove the A/C compressor belt.
pic 3
4.Loosen the adjusting nut and mounting nut, then remove the alternator belt.
5.Remove the cylinder head cover.
6.Remove the crankshaft pulley.
7.Remove the middle cover and the lower cover.
NOTE:
^ Do not use the middle cover and lower cover for storing removed items.
^ Clean the middle cover and lower cover before installation.
pic 4
8.Disconnect the Crankshaft Speed Fluctuation Sensor (CKF) sensor connector, then remove the CKF sensor.
9.Install the CKF sensor in reverse order of removal.
___________________________
Jun 19, 2019 at 2:58 PM
