No fire from coil to cylinders 2 and 4 all others are fine.
Jan 3, 2020 at 4:45 AM
MASTERWRENCH
✓Experienced Mechanic
The ignition coil on this vehicle is a single unit that supplies spark to all six cylinders. If the coil is not supplying spark to only two cylinders, this indicates an internal failure in the coil pack assembly. The coil will need to be replaced.
