No spark from coil to cylinders two and four
2003 CHRYSLER TOWN AND COUNTRY
113,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JIM12156
No fire from coil to cylinders 2 and 4 all others are fine.
Jan 3, 2020 at 4:45 AM
MASTERWRENCH
  • 258 POSTS
The ignition coil on this vehicle is a single unit that supplies spark to all six cylinders. If the coil is not supplying spark to only two cylinders, this indicates an internal failure in the coil pack assembly. The coil will need to be replaced.
Jan 3, 2020 at 1:55 PM
