Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-350
Ignition
No Spark
No spark from coil
1996 FORD F-350
43,000 MILES • 7.5L • V8 • 2WD • AUTOMATIC
TARZAN FERRELL
MEMBER
Changed coil, ignition module, pip sensor, (complete new distributor). Still no spark from coil.
Sep 28, 2019 at 1:39 AM
94 TRANSAM
Experienced Mechanic
Hi, welcome to 2CarPros.
Its obvious but I have to ask, Have you checked the fuses?
Do you have 12 volts to the coil with key on?
Have you checked for a pulse signal?
Rich
Sep 28, 2019 at 4:48 AM
TARZAN FERRELL
MEMBER
All fuses good. Power to coil. Thinking it might be PCM.
Sep 28, 2019 at 7:29 AM
TARZAN FERRELL
MEMBER
We unplugged PCM and got spark while cranking motor. Saw online this would indicate a bad PCM.
Sep 28, 2019 at 7:30 AM
94 TRANSAM
Great, let us know if you need anything else.
Rich
Sep 28, 2019 at 11:57 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
