No spark except when turning key off
6.0L • V8 • 4WD • MANUAL
TROYFIRE
304 v-8 have replaced icm coil and ignition switch with the jeep in on position only have 5.4 volts jeep will not crank any ideas??
Jun 3, 2015 at 10:57 PM
HMAC300
  • 48,601 POSTS
check battery for condition including load test . check connections at starter relay and fusible links at relay
Jun 3, 2015 at 11:21 PM
CJ MEDEVAC
  • 11,000 POSTS
YOU MEAN WHILE KEY IS IN THE START POSITION, IT'S-A-FIRING, WHEN YOU TURN LOOSE IT DIES?
AND WE'RE GETTING HOW MANY VOLTS WHILE IT IS TURNING OVER (CRANKING)?
GIMME A LIST OF WHAT HAS BEEN REPLACED (AND WHY?) (AND WAS IT RUNNING PRIOR TO THE REPLACING?)
THE MEDIC
Jun 4, 2015 at 10:11 AM
CJ MEDEVAC
  • 11,000 POSTS
PLEASE CLUE US IN TO ANY MODIFICATIONS THAT MAY HAVE BEEN MADE OTHER THAN ORIGINAL STUFF!
THE MEDIC
Jun 4, 2015 at 10:15 AM
CJ MEDEVAC
  • 11,000 POSTS
ANY NEWS?
THE MEDIC
Jun 14, 2015 at 11:36 AM
