HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
CJ7
Ignition
No Spark
SPONSORED LINKS
No spark except when turning key off
TROYFIRE
MEMBER
1980 JEEP CJ7
6.0L
V8
4WD
MANUAL
304 v-8 have replaced icm coil and ignition switch with the jeep in on position only have 5.4 volts jeep will not crank any ideas?
Thursday, June 4th, 2015 AT 5:57 AM
HMAC300
MECHANIC
Check battery for condition including load test. Check connections at starter relay and fusible links at relay
SPONSORED LINKS
Thursday, June 4th, 2015 AT 6:21 AM
CJ MEDEVAC
MECHANIC
YOU MEAN WHILE KEY IS IN THE START POSITION, IT'S-A-FIRING, WHEN YOU TURN LOOSE IT DIES?
AND WE'RE GETTING HOW MANY VOLTS WHILE IT IS TURNING OVER (CRANKING)?
GIMME A LIST OF WHAT HAS BEEN REPLACED (AND WHY?) (AND WAS IT RUNNING PRIOR TO THE REPLACING?)
THE MEDIC
Images (Click to make bigger)
Thursday, June 4th, 2015 AT 5:11 PM
CJ MEDEVAC
MECHANIC
PLEASE CLUE US IN TO ANY MODIFICATIONS THAT MAY HAVE BEEN MADE OTHER THAN ORIGINAL STUFF!
THE MEDIC
Image (Click to make bigger)
Thursday, June 4th, 2015 AT 5:15 PM
CJ MEDEVAC
MECHANIC
ANY NEWS?
THE MEDIC
Sunday, June 14th, 2015 AT 6:36 PM
Please
login
or
register
to post a reply.
Related No Spark Content
Ignition Issue
Been Reading A Post Between The Medic And Cfengineer. I Have The Same Issue. What I Know So Far: Was Running Fine And Just Died 84...
Asked by
Rickb8479
37 IMAGES
1984
JEEP CJ7
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
'84 Cj7 258 I6 Weber 32/36 Carb Tfi Igniton Upgrade....
'84 Cj7 258 I6 Weber 32/36 Carb Tfi Igniton Upgrade. No Spark! My Cj7 Has Been Garaged For 5 Years And Has Been A Hit And Miss On Getting...
Asked by
kcscj7
41 IMAGES
1984
JEEP CJ7
No Spark
This Morning Just Would Not Start. Drove Until It Did Not. Turns Over Has Plenty Of Fuel Through A New Carburetor. Have An Hei Distributor...
Asked by
Roger Walker
2 IMAGES
1985
JEEP CJ7
I Have No Spark I've Changed The Following...
83 Jeep Cj7 165,000 Mi 4.2 Engine I Have No Spark I've Changed The Following, Ignition Coil, Rotor, Dist Cap, Magnetic P/u, And...
Asked by
copeman
JEEP CJ7
1982 Jeep Cj7 No Fire
Engine Turns No Fire. Put New Pickup Coil And Ing. Model.
Asked by
leonardbaker
6 IMAGES
1982
JEEP CJ7
VIEW MORE
SPONSORED LINKS
Ignition System Testing
Ignition Coil System Test Repair - All Cars
Crankshaft Sensor Replacement
Online car repair manuals
