No Spark. Car cranks, but no spark from ignition coil.
216,540 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
LEINADLTD
  • 15 POSTS
A few days ago I took a corner from my house and the car just died. I got the car back to the house and the first thing I did was spray starting fluid down the TBI (Throttle Body Unit) to see if the car would start. The car did not start. That led me to suspecting something on the ignition side was wrong. I then removed the secondary coil wire going to the distributor cap and held it close to the strut tower to try and "see" a blue spark, as my dad was "cranking" the car. No luck. I then proceeded to check the resistance readings on the ignition coil and got 0.8 ohms on the primary side and 13.68k ohm on the secondary side. While there I check voltage from the end of the coil wire to ground, and also check the primary voltage to ground. Both read 12.41 volts. I then got my OBD-II tool and pulled codes P0401 and P0110. One code was the EGR valve and the other was the IAC (Intake Ambient Sensor). No other codes. I went on the safe side and removed the igniter and took it to AutoZone where it was tested several times using their Wells tester. All tests came back "PASSED". Thinking that something was not allowing the "coil" to collapse to induce a spark I check the CSS (Crankshaft Sensor). With the car cold it read 1348 ohms. I went to AutoZone and checked three of their CSS's and all read between 1340-1368 ohms. So, looking at a diagram from the Haynes manual I noticed that the Pick-up coil could possible cause this problem. So, I check the ohms on this and got 168 ohms. Doing some additional research some individuals have mentioned the IGf and IGt from the ECM. I do not know what else to check. I put new plugs, wires, distributor cap and rotor on a month ago. Is the coil bad? Why is there no spark with everything reading correct? Suggestions are welcomed.
Aug 25, 2015 at 10:05 AM
SATURNTECH9
  • 30,869 POSTS
Testing a crankshaft sensor that way wont always work because everything changes when the sensor is in operation. It does sound like it is out though. Here is a guide that will show you what you are in for when changing it out with some diagrams (below) on how it will be like on your car.
Next, with the key in the run position you should have battery power to the white wire with a red stripe at your coil.Also black wire with a red stripe should have a pulsing ground while cranking the engine?Check for the pulsing ground with a test light that will check your coil inputs to see if the coil is getting what it needs.
Here is a generic guide as well
Please let us know what happens so it will help others.
Cheers
Aug 25, 2015 at 12:23 PM
LEINADLTD
  • 15 POSTS
Sorry it took so long to get back to you. I used a 12 volt test light and found that the light remain solid on both the white / red wire with the key "on", and while cranking the black with red stripe wire also remained solid. There was no Flicker or pulsating on the black / red wire. This might have been due to my LED test light. What does this mean? I only have two wires coming out of my distributor for my pickup coil. What is the next step? Ok just tested the same black / red wire using a 12 volt light bulb. The bulb did not pulsate, however it did dim when the car was cranking.
Aug 27, 2015 at 2:59 AM
SATURNTECH9
  • 30,869 POSTS
So there are two wire inputs into the coil?If so one is a constant power and the other is a pulsing ground while cranking that is what causes the coil to spark . also with the distributor cap off and cranking the engine the rotor on the distributor spins while the engine is cranking?
Here is a guide and some ignition system wiring diagrams to help with the testing.
I gave both 4 and 6 cylinders just in case.
Cheers,
Aug 27, 2015 at 5:20 AM
LEINADLTD
  • 15 POSTS
Yes, the white / red wire has 12 volts on it. The black / red wire also has 12 volts and when you crank the car the test light does not pulse. We did this to make sure the timing belt was not broke. Its like the ignition coil is not collapsing to send the spark energy to the spark plugs. How can you check the pickup coil to see if the timing events are happening in order to make and break the ground on the ignition coil in order to induce a spark on the secondary side, so that spark energy is sent to the spark plugs? Remember, the igniter was tested at autozone on their wells tester and show to be good several times. What would you like me to check next?
Aug 27, 2015 at 8:02 AM
SATURNTECH9
  • 30,869 POSTS
It sure sounds like the crankshaft angle sensor is bad. I would try replacing it they go bad all of the time.
Here is a the Denso sensor on Amazon for $53.00
https://www.amazon.com/gp/product/B00PYQB40A/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B00PYQB40A&linkId=3bc24fda11629fb9ea31f9aa822f7a32
Here is some testing guides from the book:
Real Fixes
Component Tests
Common Replaced Parts
0k25k50k75k100k125k150k175k200k012
ignition control module...
distributor rotor (1)
ignition coil (1)
ignition distributor ca...
spark plug (1)
ENGINE DOES NOT START, REPLACED IGNITION CONTROL MODULE
Complaint
The customer states the engine will not start.
Cause
Confirmed the customer's complaint and found the engine did not start. Performed a visual inspection of the fuel system and ignition system components, but found no obvious faults. Removed the spark plugs and performed a visual inspection, but found no obvious faults. Connected an inline spark tester to the ignition coil secondary lead, started the engine, and found the spark was intermittent. Used a multi-meter to measure the resistance of the ignition coil and found the measured resistance was within specifications. Connected a lab scope to the ignition coil primary signal circuit, started the engine and found an erratic signal. Performed a visual inspection of the ignition control module wiring harness and connector terminals, but found no obvious faults. Key on, engine off, used the multi-meter to check for voltage and ground at the ignition control module and found both were present. Connected the lab scope to the ignition control module primary signal trigger input, started the engine and found the waveform revealed no faults with the primary trigger. This indicated the ignition control module was faulty.
Correction
Replaced the ignition control module and verified the vehicle operated properly. The customer's concern did not return.
Real Fixes
Fixed It!
Engine Does Not Start, Replaced Ignition Control Module
51?
The customer states the engine will not start. Confirmed the customer's complaint and found the...
Engine Does Not Start, Replaced Ignition Coil, Ignition Control Module
Engine Does Not Start, Replaced Fuel Pump, Fuel Pump Relay
Component Tests
Ignition Tests -> Carbureted/Fuel Injection
Tests
Koec Test
KOEC test is best used for diagnosing no start, no spark condition.
Connect test leads at ignition coil:
Yellow=coil(-)
Black=known good ground.
KOEO, primary ignition voltage must be present to continue with test.
Crank Engine and check for ICM switching at ignition coil while cranking.
As ICM switches, primary voltage spikes can be seen.
Resistance Test
Secondary ignition wire resistance
Connect ohmmeter
Red=either end of plug wire
Blue=other end of plug wire
Read amount of resistance:
10k ohms per foot or
25k ohms total resistance per wire.
Ignition Tests -> Fuel Injection
Location
Type: conventional
Best test Location:
Distributor, coil, and igniter terminals.
Component Location:
Distributor: at rear of CYL head.
Coil and igniter: at left rear of Engine compartment near brake booster.
CYL #1 Location:
(front of vehicle) firing order 1-3-4-2distributor rotates counter-clockwise
Tests
Out Of Range No Sig Test
Connect test leads:
Yellow=coil(-)
Black=known good
Ground.
Key on, primary IGN
Voltage should be
Present.
Move test leads:
Yellow=coil(+)
Black=known good
Ground.
Key on, primary IGN
Voltage should be
Present.
Ignition Tests -> Fuel Injection/Carbureted
Operation
System is conventional ignition using one ignition coil to produce high voltage for all cylinders.
Primary windings create a magnetic field that when collapsed across secondary windings, create high voltage.
This high voltage is required to overcome the greatest KV requirement in the secondary (normally the spark plug gap) this high voltage is transmitted from the coil to the spark plugs through a coil wire, dist cap, rotor and spark plug wires.
Tests
Secondary Ignition Test
Component Test Meter can be used to view secondary ignition waveforms.
CH1=Yellow secondary coil adapter.
GND=Black secondary coil adapter lead.
Black clip=known good ground.
Note: See LAB scope plug-in manual for proper hook up information.
Sweep , scale and delay may need to be adjusted depending on engine RPM and firing voltage.
Current Ramp Test
Ignition coil current can be checked using Component Test Meter & a low amp current Probe.
Connect current Probe to Component Test Meter as shown.
Perform auto zero adjustment before any measurements. This adjustment should be done prior to clamping Probe around any wire.
Press the auto zero button to zero Probe.
Clamp current Probe around the b+ side or the Control side of ignition coil. Do not clamp around both.
If coil is difficult to access, it may be possible to check coil current at the fuse box, if applicable.
Verify that Probe jaws are fully closed. If a negative waveform appears,open jaws & clamp Probe in other direction.
Ignition coil waveform should have a gradual rise or ramp as current begins to flow.
If vehicle is DIS equipped, current flow through each coil should be about the same.
If not, suspect resistance in power supply or ground circuits,or possible aftermarket assy not matched with OEM units.
If coil waveform has a sharp rise at the begining of the ramp upward, suspect shorted coil windings.
i have sure track a data base you type code symptoms etc in and this is what came up i know the ignition control module tested good on there machine but thats what came up on sure track.
Please let us know
Aug 27, 2015 at 2:44 PM
LEINADLTD
  • 15 POSTS
Wow! That is a lot of information. I was reading through that and I do NOT have access to an oscilloscope to check for waveforms. What would be your suggestion? What can I check using a digital voltmeter and a test light to see why my coil is not collapsing to induce a spark? What component(s) cause the coil to collapse to induce a spark? How can I check those components? Thanks.
I purchased the Denso unit a genuine crankshaft sensor and I placed the new component on the car and cranked the car. We are in luck! The car still started! I went one step further and bought a new coil. You guy are the best! Thanks.
Aug 27, 2015 at 3:20 PM
WRENCHTECH
  • 20,760 POSTS
This is a different expert. I was going to continue the troubleshooting in case the sensor did not fix it.
The first thing we need to do is run a few more tests to get the entire picture and see if any other systems have issues.
This is a series of tests that is used on all crank, no starts to isolate what is going on. You may have already done some of it but complete the parts that you haven't yet and we'll go from there.
Side note: That P0110 is for an IAT (intake air temp) sensor circuit..That can cause the engine to go very rich s you should get that resolved.
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
4) Do a complete compression test on all cylinders
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Sep 2, 2015 at 7:09 PM
LEINADLTD
  • 15 POSTS
Okay, let's take it from the top. I will conduct the tests that you asked; however, it may take me 2-3 days to get your results. Monday is a holiday. I will talk to you Tuesday to see what we need to do and proceed from there. Thanks.
Sep 3, 2015 at 9:20 AM
LEINADLTD
  • 15 POSTS
Okay, I have conducted all the tests that you asked for. Here are the results:
Compression Test
Cylinder # 1: 190psi
Cylinder # 2: 180 psi
Cylinder # 3: 180 psi
Cylinder # 4: 190 psi
Fuel pressure reading at fuel rail: 40 psi; Yes, it does hold pressure for several minutes.
Spark Plug Spark Test:
Cylinder # 1: no spark
Cylinder # 2: no spark
Cylinder # 3: no spark
Cylinder # 4: no spark
Voltage was available on the + B side of the coil measured on the white / red wire. This reading read 12 volts on my digital voltmeter.
Finally, checking the fuel injectors using a noid light revealed No flashing with the noid light. However, 12 volts was present on one wire of each fuel injector when measured to ground using my digital voltmeter.
Now that these tests have been completed. What suggestions do you have that I might check on this vehicle? Thanks.
Sep 6, 2015 at 4:45 AM
WRENCHTECH
  • 20,760 POSTS
OK, what you have proven is that you are lacking pulse for both ignition and injector. That is determined by the reference signal supplied by the Crank sensor. That is where I would concentrate. It can be the sensor or any related wiring or even the ECM. Here is a quick test for the sensor. CRANKSHAFT POSITION SENSOR INSPECTION NOTICE: "Cold" and "Hot" in the following sentences express the temperature of the sensor itself. "Cold" is from -10°C (14°F) to 50 °C (122°F). "Hot" is from 50°C (122°F) to 100°C (212 °F). DISCONNECT CRANKSHAFT POSITION SENSOR CONNECTOR FROM GENERATOR DRIVE BELT ADJUSTING BAR INSPECT CRANKSHAFT POSITION SENSOR RESISTANCE https://www.2carpros.com/images/external/79036105.jpg.gif Using an ohmmeter, measure the resistance between terminals. Resistance: Cold: 985 - 1,600 Ohms Hot: 1,265 - 1,890 Ohms If the resistance is not as specified, replace the crankshaft position sensor. RECONNECT CRANKSHAFT POSITION SENSOR CONNECTOR
Sep 6, 2015 at 5:00 AM
WRENCHTECH
  • 20,760 POSTS
Check out the wiring diagrams in this post a few answers up
Sep 6, 2015 at 5:37 AM
LEINADLTD
  • 15 POSTS
Thank you for the information. We checked the resistance on the crankshaft position sensor and got a value of 1450 ohms. The outside temperature was less than 100 degrees. I went one step further and check the continuity between the orange / blue wire on the crankshaft position sensor and the blue / yellow wire on the distributor. The wire ohmmed. I then proceeded to set my digital voltmeter on the 4 volt scale and as the car was cranking I observed a fluctuating voltage reading from 0.254 - 0.289 on the blue / yellow wire going into the distributor. I still have no Smart coming out of the secondary side on my mission coil. What should suggestion can I try or do you have?
Sep 8, 2015 at 6:34 AM
WRENCHTECH
  • 20,760 POSTS
Use a scan tool and see if you have an RPM signal when cranking.
Sep 8, 2015 at 7:04 AM
LEINADLTD
  • 15 POSTS
Is this the same as an obd2 scanner
Sep 8, 2015 at 7:09 AM
WRENCHTECH
  • 20,760 POSTS
Yes, anything that will give you an RPM reading.
Sep 8, 2015 at 9:11 AM
LEINADLTD
  • 15 POSTS
Using the obd2 tool I was able to use the freeze data function of the scanner to obtain an engine RPM value of 1269. What is the next step?
Sep 8, 2015 at 2:19 PM
WRENCHTECH
  • 20,760 POSTS
Using freeze frame is not a good way to do that. You need a live reading you can watch while cranking to be sure. If you do confirm a tach signal, I think I would try another distributor.
Sep 8, 2015 at 6:58 PM
LEINADLTD
  • 15 POSTS
Thank you for the information. It may take me 2 to 3 days to obtain a scan tool that can detect "live" information as the car is cranking. I will keep you updated, thanks.
Sep 8, 2015 at 11:23 PM
WRENCHTECH
  • 20,760 POSTS
Even a lot of the cheap ones will do that.
Sep 9, 2015 at 8:24 AM
LEINADLTD
  • 15 POSTS
I consider myself a pretty smart guy, but for the life of me I do not know what function to use on the scan tool to find the RPM signal that you are asking get about. It is not the freeze frame data, and the only thing left is the MIL function on this OBD-II reader. I do have access to a newer scan tool that does freeze frame, MIL, live data, and ABS. Your guidance is appreciated.
Sep 10, 2015 at 4:34 AM
WRENCHTECH
  • 20,760 POSTS
Live data is where you will find it.
Sep 10, 2015 at 7:58 AM
LEINADLTD
  • 15 POSTS
Thank you for your patience. After using the new scan tool a new code was found. That code was P0335. I will attach pictures of the scan tool in a separate attachment. The code referenced the NE signal which I believe goes to the distributor. Using the live data feature I did not see a RPM signal option. However, I did find an engine rpm option. I have attached those pictures as well. Please take a moment and review the attached pictures. Please let me know what the next course of action should be. Thanks.
Sep 11, 2015 at 2:43 AM
WRENCHTECH
  • 20,760 POSTS
There are no pictures.
Now you have a Crank Sensor code. You need to find out if you have a tach signal or not.
Sep 11, 2015 at 4:38 AM
LEINADLTD
  • 15 POSTS
Sorry about the pictures, I tried to upload them using my phone. How do I determine if I have a tach signal using an OBD-II scanner tool? What would be the next action to take? Thanks.
Sep 11, 2015 at 8:40 AM
WRENCHTECH
  • 20,760 POSTS
It may be time for you to bite the bullet and let a professional diagnose it.
Sep 11, 2015 at 8:50 AM
LEINADLTD
  • 15 POSTS
Thank you for your help. I'm sorry I don't have all the toys that you guys do to diagnose vehicles. I will let Mike know of the results.
Sep 11, 2015 at 11:01 AM
SATURNTECH9
  • 30,869 POSTS
The code reader if it has the live data feature it will give you the option of live data you select it then select all data stream.Then scroll to engine rpm then crank the engine does the rpm reading read on the live engine data while cranking the engine?
Sep 11, 2015 at 1:16 PM
LEINADLTD
  • 15 POSTS
The engine RPM displays 0 0 0 while the engine is cranking over. This is in live data mode and not the freeze frame mode. Unfortunately, I do not know how to check for the RPM signal that the technician is asking for. I'm not sure where to locate the tach signal in order for the vehicle to trigger a spark. Suggestions would be greatly appreciated.
Sep 11, 2015 at 1:39 PM
SATURNTECH9
  • 30,869 POSTS
Have you removed the crankshaft position sensor to inspect it for damage?Also inspected the toothed plate on the crankshaft pulley for damage?
Sep 11, 2015 at 3:19 PM
JDML98
Electrical problem
1996 Toyota Camry 4 cyl Front Wheel Drive Automatic 233619 miles
I have lost my IGT sinal in my Camry and have just about lost my mind trying to find it. The mechanic I took it to has replaced the igniter, coil, distributor, ECM, open circuit rela, main relay, EFI relay, and crankshaft sensor and still no spark. While trying to start the car for self diagnosis ( I used to be a technician about 5 years ago until I decide to change jobs) the battery got weak and the starter was chattering (clicking real fast) and under this condition the coil was firing. I jumped the battery with my truck and no spark until the chattering started upon being dead again. This car stalled for a couple days at low idle and then became very hard to start (5 to 15 ignition cycles) but ran great after starting and the stopped starting at all. I have no idea. Where does the IGT signal originate from?
Sep 20, 2017 at 8:09 AM (Merged)
IMPALASS
  • 3,112 POSTS
Hello Is this what you are looking for? Forgive me I may be calling it something different than you.....when you say IGT signal, that stands for. Is this the IGN - Ignition you are talking about?
https://images.2carpros.com/forum/automotive_pictures/248015_1_60.jpg
JDML98
NO, it cranks fine just no start. The IGT singnal should be 0.5v to 1.0 volts generated by the ECM to tell the igniter to ground the coil. This is the control circuit that acts much like a old set of points used to except for the fact that a set of points do not cost $503.00.
IMPALASS
  • 3,112 POSTS
Hello Even though each has the same 4 cylinder, 2.2L DOHC is this a 2D coupe, 4D sedan or wagon? Next - I wanted to shoot these two diagrams off to you so you can start looking them over as I will too.
https://images.2carpros.com/forum/automotive_pictures/248015_2_42.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_3_31.jpg
JDML98
this is a 4 door with I'm guessing California specs since my distributor in this car has only two wires instead of 4 and the external coil/igniter was only used for this year camry and the 1997 rav4.
IMPALASS
  • 3,112 POSTS
Thanks
IMPALASS
  • 3,112 POSTS
Hello jdml98 Well, to me, tell me what you think, per the drawings the only things you haven't' changed is the starter, neutral position switch, I show starter relay, but is that what you called the open circuit relay or the main relay? So my first thought is what if the starter is bad and drawing the high power. You might remove starter and have it checked for FREE at Auto Zone or O'Reilly's. Next, the wires: I would check each inch of the wires for any hardness, chaffing, hot spots, loose connectors etc. Next I attached info on this neutral switch for your to check out. Tell me what you think......
https://images.2carpros.com/forum/automotive_pictures/248015_4_17.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_5_13.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_6_14.gif
https://images.2carpros.com/forum/automotive_pictures/248015_7_9.jpg
Using an ohmmeter, check continuity across terminals specified for each switch position shown in Figs. 11 through 14. If continuity is not present, replace switch.
RDN49
  • 11 POSTS
Electrical problem
1996 Toyota Camry 4 cyl Two Wheel Drive Automatic 250000 miles
Still Struggling with Camry-stalled on Hwy; repeated cranking restart 1x, stalled again immediate; no spark now cold. Previous tech had me check ecm for igf and igt signal volt- got 5 and .7, checked wires and connectors-getting same readings at igniter connector; p/u and cps sensor check within range; tried new coil initially, and used ignter(could be bad,cannot verify), and rebuilt distributor-igt reading changed to .1? For sure, I am not sure what to check now! Thanks, Ray ( Do get battery voltage at coil and igniter)
JDML98
Your on the wrong page but have viable information. I have not lost my ignition circuit, the car turns over just fine but I have no spark from the coil. The signal from the crankshaft sensor and the distributor for a input to the ECM that is called the IGT circuit. Once the coil fires it sends a confirmation signal back to the ECM known as the IGF circuit. The IGT forms a 0.5 to 1.0 volt circuit to the igniter which turns into a ground and fires the coil. Kind of like an fancy set of old style points except for the $503.00 price tag. My CSS and distributor ohm within specs but I can't seem to find what the correct readiing from them back to the ECM is supposed to be in ohms or volts or whatever.
MASTERTECHTIM
  • 4,750 POSTS
have you checked the timing belt? every time i have had one of these with no spark i have replaced distributor and it has fixed it every time. if timing belt broke then distributor will not turn also causing no spark.
IMPALASS
  • 3,112 POSTS
Okay - I understand. Since I don't totally understand some of your terms etc, you may have to do a little more explaining so that I can better assist you. I think, based off of the last post, this is closer to what you are looking for but, some of the info when I copy to send to you doesn't' come out readable which is no good for you so we may have to try me sending it to you different. Maybe if you can not make out what you need, provide an email address and I will try sending it that way instead of attaching it to the post. Next, what do you mean when you say, CSS. I see the IGF, IGT on the wiring diagram but do not see the CSS. So it will help me if I know what it is. Also, I am sending you the entire wiring diagram which is unreadable even when I print it. But I have blown up the igniter and distributor part for you to better see. The last 4 pics are the ECM blown up but it took 4 to do it. I would cut it off at one point, then that same wire will be the bottom one on the next so you can see the order. So from here, if you can guide me where you need, I will blow up certain areas and attach that way, then with the pin information I sent, maybe you can zero in on what you need. Let me know how this does........and we will take it from here
https://images.2carpros.com/forum/automotive_pictures/248015_a_2.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_b_2.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_g_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_c_2.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_d_2.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_e_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_f_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture1_2.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture4_1.jpg
