No spark at the plugs
1963 CADILLAC SERIES 62
78,000 MILES • 6.6L • V8 • 2WD • AUTOMATIC
ALAN VAN MATER
When cranking the engine there is spark at the points, but none at the end of the plug wires.
Oct 2, 2018 at 10:34 AM
Good morning,
Is there spark coming out te top of the ignition coil?
Check there first. If you have spark, then inspect the cap and rotor.
If you do not have spark, it may be the coil itself that has failed.
Also, make sure the point gap is .018.
Oct 2, 2018 at 9:27 PM
ALAN VAN MATER
Thanks, I will check it. I will let you know.
Oct 2, 2018 at 11:52 PM
Sounds like a plan.
Oct 3, 2018 at 12:10 AM
ALAN VAN MATER
Thank you Roy, installed ignition coil, condenser and wires. Car
started right up.
Oct 3, 2018 at 11:51 PM
Nice, good job.
You are welcome. Always glad to help.
Oct 4, 2018 at 1:42 AM
