When i turn my ignition on and i have number one spark plug out in boot. It has a consistent spark with just key on.
Sep 18, 2019 at 10:00 AM
MASTERWRENCH
✓Experienced Mechanic
Shannon,
That’s a very interesting condition you’re describing. Generally, the ignition system isn’t able to produce a spark unless the distributor is rotating and supplying a pulse to the coil or ignition module. Is there any chance you can attach a video of what you’re seeing?
