Son in law brought it to repair so it has multiple wiring issues from past repairs! I put a new fuel pump, filter, distributor, ignition module, coil, wires, plugs, and it did fine for a day then it ceg crank sensor, and cam sensor, and you could turn it off and crank it back up and it would have the code and run bad. so, they had spliced the lines to the crank senso so I put a new pigtail on and new crank sensor now it won't start, you can hear the pump run but no spark, all fuses are hot and good. There is power to coil and cont mod and power to the crank sensor, and no security light. So why won't it fire?
Dec 27, 2021 at 10:27 AM
