Engine was running then it shut off
108 MILES • 1.6L • 4 CYL • 2WD • MANUAL
ERIC LEIKER
Car was running then shut off. Will turn over, has gas, but no spark. Replaced coil pak and crank sensor.
May 3, 2018 at 6:11 PM
  • 55,732 POSTS
It sounds like the main power relay is not working. Here is a guide to help you test the relay:
Here are the fuse panel and relay locations for your car. Check out the diagrams (below).
Cheers, Ken
May 6, 2018 at 5:58 AM
