No spark at the coils
180,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DUSTIN KINGSLAND
I replaced timing set and water pump. All sensors have been replaced (crank position sensor and both cam sensors) still not getting spark at the coils. The odds of all 6 coils going bad at once, are astronomically low. What am I over looking or missing that could cause my no spark issue?
Mar 29, 2020 at 8:06 PM
Do you have any codes with this? Clearly there could be other issues than just the sensors but that includes wiring and a control module.
Was the vehicle running properly prior to the repair?
Does the engine crank properly, just no spark?
Let's start with codes and this info then we can go from there. Thanks
Mar 30, 2020 at 3:20 AM
DUSTIN KINGSLAND
Had crank and cam sensor codes replaced all them still same issue.. I have replaced the condenser, all fuses and any other main thing I can think of.
Mar 30, 2020 at 5:35 AM
Okay. Thanks. Do you have any codes with this? If you have a cam or crank code then there are other things that can cause those codes then just the sensor so we need to start with if there are codes. If you can't pull codes, just check with some local parts stores and see if they will pull them for you. Thanks
Mar 31, 2020 at 2:28 AM
