No spark
142,000 MILES • 0.5L • V6
ROBERT RYDER
Was running just stopped. Try to start not fireing
Jan 23, 2019 at 7:49 AM
  • 110,248 POSTS
Hi and thanks for using 2carpros.com
The most common cause of this is a bad crankshaft position sensor. Take a look through this link:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Here is a link that shows in general how one is replaced.
___________________
The easiest way to determine if the sensor is bad is by using a live data scanner and checking for an RPM signal when the engine is cranking. If you have one, do that. If there is no signal, replace the sensor.
Here are specific directions for replacing the sensor. The attached pictures correlate with these directions.
REMOVAL
1. Disconnect the battery ground cable. For additional information, refer to Battery.
See Pic 1
2. Remove the Crankshaft Position (CKP) sensor shield.
1 Remove the CKP shield nut.
2 Remove the CKP shield.
See Pic 2
3. Remove the CKP. Disconnect the electrical connector.
INSTALLATION
1. To install, reverse the removal procedure.
______________________________________
Jan 23, 2019 at 11:29 AM
ROBERT RYDER
Thankful so much.I thought that might be the problem I just wanted ur thoughts. Will ck.today and let you know.tks.again
Jan 23, 2019 at 3:03 PM
  • 110,248 POSTS
Happy to help. Let me know what you find or if you have other questions, feel free to ask.
Jan 24, 2019 at 8:53 AM
ROBERT RYDER
Change crank sensor still no spark
Jan 24, 2019 at 10:21 AM
  • 110,248 POSTS
Have you checked for diagnostic trouble codes?
Also, if you have a live data scanner, check to see if there is an RPM signal and let me know what you find.
Jan 24, 2019 at 11:22 AM
