No spark?
168,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
RUSSTY
Have compression.
No spark no codes.
Tachometer worked.
Now it doesn't.
I suspect crank sensor.
Jul 24, 2022 at 10:36 AM
  • 110,246 POSTS
I agree with you. If you have no spark and the tach isn't moving, the first suspect is the crankshaft position sensor.
Here is a link that explains in general how to replace one:
If you look below, I attached the directions specific to your vehicle. On this engine, you will need to remove the starter motor to access the sensor.
joe
Jul 24, 2022 at 3:39 PM
