No spark after replacing clutch?
178,000 MILES
ANGELABOSLER
No spark after replacing clutch. The first code said crankshaft position sensor. we replaced still no spark.
Aug 23, 2024 at 2:24 PM
  • 55,743 POSTS
The number one reason for no spark after repairs is one of the system grounds has been left off and is not connected. The only thing is, it says the PCM grounds are at the right side of the dash, did you do any work in that area? Check out the images (below). Let us know what you find.
Aug 24, 2024 at 3:43 AM
