It has no spark at all?
250,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
LESLIEBARNES
I have the truck listed above c1500 4.3 v6. I was driving it and it backfired the stalled and wouldn't crank again. It has no spark at all. I've changed the spark plugs, Distributer cap, wires, rotor, ignition coil, and ignition control module. It still won't crank and I'm still not getting and spark. I've tried to locate the crankshaft position sensor but can't locate it. Help.
Jan 31, 2025 at 8:10 AM
  • 55,711 POSTS
I would remove the distributor cap and have a helper crank the engine over the make sure the rotor is turning. Next use a test light to see if there is power at the coil with the key on. (pink wire). Here is a guide to help you:
https://www.2carpros.com/articles/no-ignition-spark
Please go over this guide and get back to us.
Feb 2, 2025 at 1:03 AM
