No spark
148,000 MILES • 3.0L • V6 • TURBO • 2WD • AUTOMATIC
ROBERTDIANNA97
No spark from coils, no rpm on rpm gauge. Had multiple misfire code and -40 on coolant temperature sensor with code.
Sep 28, 2020 at 5:03 AM
  • 110,248 POSTS
If there is no RPM signal, the first thing I would check is the crankshaft position sensor. Take a look through this link:
Here are directions specific to testing the one on your vehicle. The attached pics correlate with the directions.
_______________________________
1999 Lexus Truck RX 300 FWD V6-3.0L (1MZ-FE)
Component Inspection
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Crankshaft Position Sensor Testing and Inspection Component Tests and General Diagnostics Component Inspection
COMPONENT INSPECTION
NOTE: "Cold" and "Hot" in these sentences express the temperature of the sensor itself. "Cold" is from - 10°C (14° F) to 50°C (122°F) and "Hot" is from 50°C (122°F) to 100°C (212°F).
INSPECT CRANKSHAFT POSITION SENSOR RESISTANCE
Using an ohmmeter, measure the resistance between terminals.
Resistance:
pic 1
pic 2
pic 3
RESISTANCE
If the resistance is not as specified, replace the crankshaft position sensor.
Let me know what you find. Also, let me know the codes that were pulled when it was checked.
Sep 28, 2020 at 10:05 AM
