No spark
350,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
BARTON K
Van runs fine for about an hour then no spark. after a few hours starts right up and runs about an hour again. Endless cycle.
Aug 2, 2019 at 5:16 AM
Hi Barton,
This sounds like a crank sensor issue. Here is a guide that walks through the symptoms of a cranks sensor issue. Pay particular attention to its intermittent operation when it gets hot.
Attached is the procedure to replace it if you find it is the issue. Thanks
Aug 2, 2019 at 9:31 AM
