No spark will not start
67,300 MILES • V8 • 2WD • AUTOMATIC
MR.LOPEZ
My car dose not want to start up. it will crank but will not start. I have no spark on spark plugs. I put in a new distributor cap and ignition coil and distributor rotor, but still no spark.
Jul 22, 2017 at 1:16 AM
HMAC300
  • 48,601 POSTS
check the pickup coil for resistance, then check ignition module in distributor it should be 500-1500 ohms. See picture. if you have a tachometer lead disconnect it and see if it starts. auto parts can check module.
Jul 22, 2017 at 3:32 AM
