There is no spark but, the injectors work?
111,222 MILES • 2.4L • 4 CYL • 2WD • MANUAL
BARAKAT
  • 8 POSTS
l have changed a new engine, there is no spark but the injectors work. Please help me.
Mar 14, 2023 at 6:04 AM
  • 110,246 POSTS
This model wasn't offered in the US, so I have very limited technical information related to it. However, I will try my best to help.
First, if you have a live data scan tool, check to see if there is an RPM signal when cranking the engine. If there is no signal, suspect a faulty crankshaft position sensor or it may a wiring or connector issue as well. Additionally, take a look through this link, you may find it of interest:
Also, if you haven't already, scan the computer to see if there are diagnostic trouble codes. That may be very helpful.
Try this and let me know what you find.,
Mar 14, 2023 at 2:04 PM
