I would also check for 12 volts at the coil with the key on. Check out the images (below). Let us know how it goes.
Image (Click to enlarge)
Dec 30, 2024 at 2:36 AM
KAYLA SAMMS
MEMBER
Well, it has hardly any fuses at all and its throttle body.
Dec 30, 2024 at 3:08 AM
✓Experienced Mechanic
Okay did you find any bad ones? Also is there power to the ignition coil?
Dec 31, 2024 at 2:59 AM
KAYLA SAMMS
MEMBER
Yes there is power to it.
Jan 1, 2025 at 6:56 AM
Okay, not let's remove the distributor cap and crank the engine over to see if the rotor spins? If so, I would replace the ignition module which fail on these trucks, here is how, let me know.
