A few months ago, the car randomly wouldn’t start. It was a crank no start. I looked online and checked the fuel pump which was fine and had a no spark issue. I replaced the spark plugs, and it was the same. Then I replaced the coils which didn’t solve the issue and after that I replaced the control module which fixed the issue. The car worked for about 2 weeks before the same thing happened. The fuel pump is fine and I’m not getting any spark. I replaced the module and this time it didn’t solve the issue. The module is getting power but isn’t giving power to the spark plugs. I took apart the fuse box and all the wires and ground connection seemed to be fine. All the fuses and relay are also fine. What could my issue be?
Dec 26, 2024 at 5:37 AM
