No Spark?
175,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
BILL21551
I have a no-spark condition. It cranks fine. According to the service manual, there should be a 1-4V AC signal to the ignition module coming from the VCM from pin 9 on connector 3. There is none. The manual says to replace the VCM. I did. There is still no signal, no start.
What conditions would exist such that there would be no signal going to the ignition module?
Aug 3, 2023 at 2:39 AM
BILL21551
I solved the problem. It was the crankshaft position sensor. I couldn't find anything in the service manual to indicate this as a possible source of the no-signal condition, and there was no code to indicate a malfunction. Thanks for trying to help.
Aug 3, 2023 at 8:06 AM
BRENDON S
  • 653 POSTS
Hello BILL21551,
Thank you for sharing that information with us. It will help someone in the future. I am glad to hear you got everything working.
If you need anything else, please let me know or start a new question.
I apologize I wasn't able to get to you sooner.
Thank you,
Brendon
Aug 3, 2023 at 8:37 AM
