Hey my name is Matt I have the car listed above and I bought it 2 weeks ago. here is the story: I was driving home and the temperature pinned on the highway and I turned the key off and pulled off the car shut off so I jumped it. starts up right away as I'm pulling into my lot it stops and wont start even after jumping it. so I replaced the spark plugs and the coil. I tested the old coil it was shot so was the relay for the fuel pump. I tested the horn relay and that works. so I plugged it in and it still wont fire. the spark plugs I do not know what to do. when I turn the engine over it has compression so it's turning over. I checked the fuel line when i crank it over there for sure a lot of fuel going in.
Jan 26, 2020 at 12:28 PM
