no spark
300,000 MILES
JEEP1990
oops i did forget the engine size. it is a 4.2 in line 6 with a Weber Carburetor. it does not have a port too plug in a code reader . they did not have them until later years . and the mechanic is willing too stop by to plug in his portable computer to the ports next too the battery . but his scedual is not letting him come yet and since it won't start and i don't have the money for a tow . i have bin stuck waiting for over 6 months to find the problem . so any HELP would be greatful .Carrson mccleary .......
Apr 23, 2013 at 5:21 AM
JDL
  • 16,098 POSTS
You can try to access mil codes, see if it will work? You turn key till the dash lites come on, no further. Cycle the key on--off, on--off, on, then the mil on the dash starts flashing. You count the flashes to get the codes. Your looking for two digit codes.
How long since a tune-up? Did you check for primary voltage at the coil?
Apr 23, 2013 at 5:57 AM
