No spark? I've replaced the crank sensor
160,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
PMARTIN237166
I've replaced the crank sensor and the complete distributor from a running jeep and coil. i have tried to change computer. also, i left the original computer since it didn't work. Any advice and or wiring diagrams?
May 29, 2023 at 10:26 PM
  • 55,721 POSTS
It sounds like the auto shutdown relay is bad here is the location of the relay and the engine and ignition wiring diagrams in the images below so you can see how the system works.
This guide may help as well:
NOTE: The Automatic Shutdown (ASD) relay is installed in the Power Distribution Center. Relay location is printed on the Power distribution Center cover.
REMOVAL
1. Remove the Power Distribution Center cover.
2. Remove the relay by lifting straight up.
INSTALLATION
1. Push the relay into the connector.
2. Install the relay cover.
May 30, 2023 at 11:07 AM
