no spark
70,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
RICHARDHAAN
injector coil fuse blows with key in start position.
Feb 5, 2020 at 6:09 PM
Good morning,
In the on position, do you have power to the injectors and the coil?
Do you have any codes set?
I attached a wiring diagram for you to view. You could have a shorted coil or a shorted injector. You will need to disconnect the coils and injectors to see if the fuse still fails. The dark green wire is the feed to both.
Feb 5, 2020 at 8:41 PM
