No spark
190,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
ANGIE WRIGHT
  • 10 POSTS
Car started acting goofy and knocking, then shut off. Tried to restart and it acted like it wanted to fire but would not. Hauled car home. Disconnected battery and charged it. Hooked back up it turns over fine, but has no spark. Any ideas? I am at a loss on what to check.
Dec 4, 2018 at 9:43 AM
  • 110,248 POSTS
My first suspect is the crankshaft position sensor. If it came disconnected or has gone bad, you will lose spark. The easiest way to check it is by using a live data scanner and checking to see if there is an RPM signal when cranking.
Here are two links. One discusses symptoms of a bad sensor, and the second discusses how, in general, one is replaced.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Here is a link the discusses the most common reasons for a crank no start condition:
______________________
If you determine the sensor is bad, here are the directions for replacement specific to your vehicle. The attached pictures correlate with these directions.
ROCEDURES
Fig. 9 Crankshaft Position Sensor
See Pic 1
REMOVAL
1. Remove speed control servo from driver's side strut tower.
2. Remove crankshaft position sensor retaining bolt Fig. 9.
3. Pull crankshaft position sensor straight up out of the trans-axle housing.
4. Disconnect crankshaft position sensor electrical connector from the wiring harness connector.
INSTALLATION - ADJUSTABLE
Some vehicles may be equipped with an adjustable crankshaft position sensor. This can be identified by an elongated mounting hole in the sensor.
Fig. 10 Crankshaft Position Sensor And Spacer
See pic 2
If the removed sensor is to be reinstalled, clean off the old spacer on the sensor face. A NEW SPACER must be attached to the sensor face before installation. If the sensor is being replaced, confirm that the paper spacer is attached to the face of the new sensor Fig. 10.
1. Install sensor in trans-axle and push sensor down until contact is made with the drive plate. While holding the sensor in this position, install and tighten the retaining bolt to 12 Nm (105 in lb) torque.
2. Connect crankshaft position sensor electrical connector to the wiring harness connector.
3. Attach connector to heater tube bracket.
4. Install speed control servo. Tighten nuts to 9 Nm (80 in lb) torque.
INSTALLATION - NON-ADJUSTABLE
1. Install sensor in trans-axle.
2. Install and tighten the retaining bolt to 12 Nm (105 in lb) torque.
3. Connect crankshaft position sensor electrical connector to the wiring harness connector.
4. Attach connector to heater tube bracket.
5. Install speed control servo. Tighten nuts to 9 Nm (80 in lb) torque.
_______________________________
Let me know if this helps. Also, this engine does have a timing belt. When cranking to start, does it sound normal, like it is turning faster than normal, uneven?
I hope something here is helpful. Let me know if you have questions.
Dec 4, 2018 at 10:06 AM
ANGIE WRIGHT
  • 10 POSTS
Thank you I will try this and let you know. My tachometer did not work in the first place. Every now and then it would start work. But I will let you know!
Dec 5, 2018 at 7:05 AM
ANGIE WRIGHT
  • 10 POSTS
What is this black part under the rotor of the distributor? It is cracked all the way to the middle bolt that holds it in place.
Dec 5, 2018 at 10:22 AM
  • 110,248 POSTS
Looking from the side, I cannot tell what is cracked. I attached a picture of an ignition rotor and two of the components in the distributor. Let me know if you can identify the part with these pictures.
Dec 5, 2018 at 10:42 AM
ANGIE WRIGHT
  • 10 POSTS
This? It goes cap, rotor than this to cover coil?
Dec 5, 2018 at 6:06 PM
  • 110,248 POSTS
That appears to be nothing more than a dust cover or insulator to prevent arcing within the distributor.
Dec 6, 2018 at 7:51 AM
ANGIE WRIGHT
  • 10 POSTS
So we took apart distributor got to ignition coil and the adapter plug-in to plug into the coil was completely shot.
Dec 6, 2018 at 11:44 PM
ANGIE WRIGHT
  • 10 POSTS
Here it is:
Dec 6, 2018 at 11:49 PM
ANGIE WRIGHT
  • 10 POSTS
All put back together new coil pack new adapter for it. And it has still got no spark. Doing the same thing.
Dec 7, 2018 at 1:56 AM
ANGIE WRIGHT
  • 10 POSTS
Going to replace the CPS.
Dec 7, 2018 at 3:48 AM
  • 110,248 POSTS
A bad crankshaft position sensor will prevent spark. Let me know what you find.
Dec 7, 2018 at 8:34 AM
ANGIE WRIGHT
  • 10 POSTS
Halifax switch was bad. Replaced and put back together. Got new everything inside distributor. New cps and adapter. Car fired up drove down the road. Then dash light went out. Hit the brakes they come back on. Checked a fuse for ABS because light was blinking. Changed with a different 20 fuse. Car has no spark and just cranks over again. Ugh. Junkyard. I am done.
Dec 8, 2018 at 11:05 AM
  • 110,248 POSTS
Welcome back,
Angie, you said the light was flashing. Was it the check engine light? That indicates a misfire. Also, and I have a feeling I am going to make a fool of myself, but what is a halifax switch? Did you check for trouble codes since the light was flashing?
Since it ran until you hit the brakes, I want you to try something. (I have a feeling you have a loose connection at some point. Disconnect the battery once you get both terminals off, zip tie them together and let them like that for about ten minutes. Then reconnect and see if it starts. This discharges all the capacitors. If it is a sensor that shut it down, it may restart.
Dec 8, 2018 at 12:05 PM
