Does not start, no spark
57,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
AUSTIN DIEHL
So, I bought the car listed above just a few weeks ago and was told that the fuel pump was no good. I replaced the fuel pump, and it ran fine for a few days then it started to randomly shut off. I went and got seafom and ran it through it and it ran fine, and I let it run while I started replacing the front struts when it just shut off and would not start again. I replaced the coil cover along with the packs and there is still no spark, I look at fuses and they seem fine as well. I am stumped and I don't want to give up on it any ideas on what it possibly could be?
May 30, 2022 at 12:01 PM
  • 110,248 POSTS
What you described sounds like a faulty crankshaft position sensor. Take a look through this link and let me know if anything mirrors what you experience:
Next, if the car has a tachometer, crank the engine, and watch the tachometer to see if it moves at all. If it doesn't, chances are it is the sensor.
One other thought. Here is a link that explains how to retrieve codes for this vehicle. It has an OBD1 system and doesn't require a scan tool. All you will need is a short jumper wire or even a paper clip.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know what you find or if you have questions.
May 30, 2022 at 2:22 PM
