No sound from radio
2000 NISSAN MAXIMA
280,000 MILES • V6 • AUTOMATIC
GFAL
I recently have installed a Pioneer DEH-4900BT into my car it is the SE model. i bought the radio from Amazon and had good ratings as well purchased the wiring harness and diversity antenna cable. I connected the wires with the harness matching the colors, and connecting ground wire its my first time installing the radio myself. after the installation process i tested my radio and it was functioning well not errors just no sound coming from my speakers. i double checked the wires and the radio. Radio was in new condition when I bought it so, would it be the fuse ? Or?
Nov 2, 2017 at 2:35 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
No, not a fuse. the fuse would just on the power going to the radio, even if there is also a fuse in the rear of the radio itself and I believe there may be. I just bought a Pioneer last year and that model you mentioned looked familiar. Let me see if I can find out if that has a fuse in the back or not. I will be right back.
Nov 2, 2017 at 9:56 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Yes, page 20 of the owners manual shows a 10 amp fuse in the back.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X4900BT_OwnersManual060816.pdf
Nov 2, 2017 at 10:01 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Did you have an owners manual to follow the wiring diagram with?
If not, it is on that same page.
Nov 2, 2017 at 10:04 AM
GFAL
I will double check on that and let you know, thank you.
Nov 2, 2017 at 10:07 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay.
Nov 2, 2017 at 10:08 AM
