No Signals or Flashers after Head Gasket repair
2006 PONTIAC TORRENT
V6 • 2WD • AUTOMATIC
KIRTONSA
2006 torrent, I have replaced the heater core, thermostat and head gasket. Now the signal lights and hazards don't work. Any ideas?
I have changed the fuses and still have no ding when signal lights should be on.
Before the head gasket was fixed I could not turn the key at all and I had the car towed to the shop. Not sure what happened, but now that the head gasket is fixed the signal and hazards are broken. I can start the car and the key does not stick anymore like it did before the head gasket job. Not sure what has changed.
Oct 5, 2014 at 1:05 AM
HMAC300
  • 48,601 POSTS
see if you are getting power through the turn signal switch . might have been a problem with ignition switch causeing it.
Oct 5, 2014 at 9:01 AM
