No signal to A/C compressor relay
  • 52,797 POSTS
Sounds good.
Monday, September 2nd, 2019 AT 4:43 PM
DARKFREELIFE
  • 36 POSTS
I'm back. I think I did the testing wrong. I was by numbers of the relay but I think is not right.
Key on I do get 14 volts on 2 pins according to the relay numbers is pin 30, 86? What are the chances that the numbers of relays are wrong? Out of the 4 pins of the relay, only 2 of them supposed to be hot correct?
Monday, September 2nd, 2019 AT 5:25 PM
  • 52,797 POSTS
Yes.
Tuesday, September 3rd, 2019 AT 12:10 AM
DARKFREELIFE
  • 36 POSTS
Okay, so that means the relay is working and I am getting control voltage.
Does that mean the AC pressure switch is the issue?
Tuesday, September 3rd, 2019 AT 10:52 AM
  • 52,797 POSTS
No, if the relay is clicking, the compressor should come on.
Tuesday, September 3rd, 2019 AT 11:13 AM
DARKFREELIFE
  • 36 POSTS
My last message did not post. My relay was clicking because I was jumping the wrong pins
30, 85 are getting power, without any jumping wirers.
Tuesday, September 3rd, 2019 AT 11:27 AM
  • 52,797 POSTS
Okay, then the ground for the control side, which is the PCM, is the issue. It will not ground the relay until it sees the correct signal from the pressure switch.
Do you have a scan tool to monitor the switch?
Tuesday, September 3rd, 2019 AT 11:44 AM
DARKFREELIFE
  • 36 POSTS
I have a basic scanner wont read any AC sensor. In case of switch is the problem you thing might be a broken wire or something else? Last shop I took it they did trace down to the switch not getting any power. That's when they said ECM was bad and I bought a new one put it on and nothing.
Tuesday, September 3rd, 2019 AT 12:37 PM
  • 52,797 POSTS
Double-check for voltage to the pressure switch. You should have 5 volts.
Tuesday, September 3rd, 2019 AT 1:03 PM
BRIAN.MCCAUL
Can I ask a question when ASEMASTER6371 says to replace the fuse box is this correct or is it the replay box as I have identical problems “There is a common bus bar that feeds different terminals.
You need the whole fuse block.
Yes, you can jump it temporarily until you repair it correctly.
Roy”
Saturday, April 15th, 2023 AT 6:31 AM
AL514
  • 4,793 POSTS
Hello, you will have to make a new post for this question. It is required for new questions. This post is 3 years old. Thank you.
Tuesday, April 18th, 2023 AT 10:16 AM
