I am expecting shift and it does not happen
144,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
NUGENTPM
  • 8 POSTS
Shifts great from first to second. At about 35 mph I am expecting shift and it does not happen. At this point I let off gas because rpms are up and I do not want to damage engine. No codes,
Oct 9, 2018 at 8:48 AM
Good evening.
I would verify that the TPS sensor is working correctly as that is the sensor that tells the module when to shift.
Also, when was the last time you changed the oil/filter in the transmission?? it could have a partially clogged filter.
Apr 13, 2021 at 12:01 PM
NUGENTPM
  • 8 POSTS
Thank you for the quick reply. I will verify tps sensor. Transmission fluid looks pink and clear, does not look or smell burnt. I will change fluid and filter then try it out. I will get back with results.
You are welcome.
Always glad to help.
Keep us updated.
NUGENTPM
  • 8 POSTS
Verified tps to change voltage as throttle moved. Changed transmission filter fresh fluid. Seems better but it still shifts down at about 35 mph.
Apr 13, 2021 at 12:02 PM
Okay, you have covered the basics.
These transmissions are known for valve body issues. You will need to have someone check it for you to verify it is just the valve and not an internal failure.
NUGENTPM
  • 8 POSTS
Thank you for reply. I forgot to mention that there is still no codes.
NUGENTPM
  • 8 POSTS
Can I access shift solenoids and valve body while still in vehicle?
NUGENTPM
  • 8 POSTS
I see valve body cover on side.
Yes, that is assuming it is the issue.
Procedure below
REMOVAL
NOTE: The oil pump and valve body are removed as an assembly.
1. Disconnect battery ground cable, then remove battery, battery tray, and remote air cleaner.
2. Position supply hoses, vacuum hoses, and wiring away from pump and valve body cover.
3. Remove shift lever.
4. On models equipped with Anti-lock Brake System (ABS), remove splash shield cover, then disconnect brake reservoir hose and cap to prevent contamination.
5. On all models, remove EGR bracket attaching bolts, then install lifting eye.
6. Remove throttle body bracket attaching bolt, install lifting eye, then using suitable equipment support engine.
7. Remove lefthand transaxle mount.
8. Remove transaxle side pan upper attaching bolts.
9. Raise and support vehicle.
10. Remove lefthand front wheel and tire assembly.
11. Remove inner fender cover and position aside, then disconnect ride height sensor.
12. Remove rear transaxle mount attaching bolt.
13. Loosen but do not remove two lefthand subframe attaching bolts.
14. Remove two engine support mount attaching bolts.
15. Remove four lefthand engine support attaching bolts, then remove the engine support.
16. Position suitable drain pan, then remove remaining transaxle side pan attaching bolts and remove pan.
17. Using suitable screwdriver, place manual shift shaft in Park position.
18. Disconnect upper bulkhead electrical connector wiring retainer clip from valve body.
19. Disconnect electrical connectors.
NUGENTPM
  • 8 POSTS
Thank you. Looked at procedure, I think I will call transmission shop and take it from what they estimate a repair for.
Good idea. like I said, it is a very involved job
NUGENTPM
  • 8 POSTS
Just to keep you updated, I took car to transmission repair shop for diagnostics, unfortunately they said transmission would need to be replaced. At this point this repair will cost more than what car is worth. Thanks again for all the help. It was a hell of a run!
You are welcome.
Good luck.
We are always glad to help.
