Tachometer, Speedometer, Odometer, Gear Indicator are not working?
390,000 MILES • 5.7L • 2WD • AUTOMATIC
4LASO4
No rpm, speedometer, odometer, gear indicator and struggles to get engaged into first gear. It is intermittent. I changed the ignition switch which worked for a minute.
Aug 28, 2023 at 8:47 PM
  • 55,766 POSTS
I would check the fuses and if they are okay it sounds like the IPC needs to be replaced, here is a video of the job being done on a similar vehicle. This guide can help you check the fuses:
https://youtu.be/_HEC44xENxw?si=pU7Jhc1hAS_Sk094
You can get a preprogrammed unit by searching Google or Ebay. To confirm the issue, check the grounds and power supply to the cluster, here is a guide to help:
You might want to try removing the cluster wiring connector and reinstalling it to see if it is a bad connection. Here as the cluster wiring diagram so you can see how the system works Check out the images (below). Please let us know what happens.
Aug 29, 2023 at 7:19 AM
