Really rough idle and will not accelerate past 1,000 RPMs?
265,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
CURTISFAWKES
While accelerating to highway speeds it stalled out. now has rough lumpy idle and won't go over 1,000 RPMs.
Mar 14, 2021 at 1:13 PM
  • 110,248 POSTS
Were there any strange sounds or smells when this happened? This could be several different things causing this. For example, a failed fuel pump, camshaft or crankshaft position sensor issue, a plugged catalytic converter, and so on.
What I suggest is this. The first thing that should be done is to scan the computer for diagnostic trouble codes. This should point us in the right direction.
Here is a quick video showing what needs to be done. I realize most people don't own a scan tool, but often times a parts store will lend one to you.
https://youtu.be/b2IJGfImVvw
Do this and let me know the results. I will watch for your reply.
Take care and God Bless,
Mar 15, 2021 at 1:40 PM
