Transmission has no reverse?
22,000 MILES
FELIZ DAMITA SILVAS
No reverse.
Jan 19, 2021 at 5:45 AM
SEVAG P
  • 405 POSTS
hello.
first check for fault code to narrow down our problem it can be a solenoid or mechanical from the inside of the transmission, i recommend to check automatic transmission fluid level and the quality if any metal particles inside.
check our link below how to do that.
Let us know what happens with you.
thank you
Jan 19, 2021 at 7:08 PM
SEVAG P
  • 405 POSTS
hello again,
Can you please check to see if the selector lever is on reverse, rear reverse lights work? if not perform adjustment as described the procedure and diagrams below.
thank you.
Jan 19, 2021 at 10:00 PM
