No reverse lights or buzzer
177,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
ALEXGOR
Was trying to find reverse light wire to connect rear view camera and now have no reverse lights or reverse buzzer. also could not locate reverse light wire.
please help, thank you.
Jun 7, 2020 at 11:09 PM
  • 110,248 POSTS
This vehicle isn't offered in the US so I have no schematics. However, I will try to help. When you were looking, did you disconnect anything?
Jun 8, 2020 at 12:15 AM
ALEXGOR
Hi Joe , i did not disconnect anything at all .
But l did touch reverse camera wire on the taillight wiring loom when l was trying to find the reverse light wire .
Jun 8, 2020 at 7:16 PM
  • 110,248 POSTS
Chances are that is where the problem is. Do me a favor, since I don't have a schematic to look at for this vehicle, make sure nothing was left loose or has come disconnected. Also, since you were moving things around, identify in the owner's manual which fuse is for there reverse lights and see if it is okay. When you check it, in addition to looking at the fuse, make sure there is power to the fuse.
Let me know what you find.
Jun 9, 2020 at 2:11 PM
