No reverse lights
188,000 MILES • 5.7L • V8 • TURBO • 4WD • AUTOMATIC
LYLE LOZIER
I have no reverse back up lights. I also can't find the NSS to replace it. Can you show me a picture please?
Jun 29, 2019 at 6:29 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
First, I'm attaching a tutorial showing how to test your trucks wiring.
Also, I've attached below a picture of your trucks reverse light circuit.Hope this helps and thanks for using 2CarPros.
Danny-
Jun 30, 2019 at 11:15 AM
LYLE LOZIER
All the wiring looks fine the bulbs are good. Where else should I be looking? Is there a sensor somewhere else like on transmission?
Jul 1, 2019 at 1:28 AM
  • 55,711 POSTS
If I can jump in here. it sounds like the TIPM is out. To be sure use this wiring diagram to check for power with the guide on how to use a test light. It easy to replace the TIPM because it self initializes. Here are diagrams and instructions on how to replace the TIPM below.
Jul 3, 2019 at 12:01 PM
