No reverse
176,000 MILES • 5.4L • 6 CYL • 4WD • AUTOMATIC
JENNIFER MAYS
My first major issue. I can drive, just not reverse. The lock engine icon light comes on and I can't move in reverse, even in neutral. Help please!
Jan 10, 2019 at 7:02 AM
Good morning,
When was the last time you had the oil/filter in the transmission?
Is the check engine light on? If it is, can you have it read? A parts store will check it for free. That will lead us in a direction for the failure.
In most cases, the issue is internal in the transmission not a sensor or solenoid.
Jan 10, 2019 at 11:49 PM
JENNIFER MAYS
Thank you!I will definitely go by auto part store this weekend.
Jan 11, 2019 at 2:28 AM
Sounds like a plan.
Let us know what the results are from the code check.
Jan 11, 2019 at 2:47 AM
